Fluent case file........
Old   October 10, 2005, 02:03
Default Fluent case file........
Matt
Hello every one,
I was wondering if any one can help me with a little problem I am having here.
I have a 2D fluent case file and it contains a customised 2D geometry of an airfoil. I wanted to model the thing in 3D however, I dont have the IGES file for it, all I have is the .cas file and I can see the profile there.
Is there any way I can get the outline of the profile inform of a sketch inside a CAD package by any means? I know we can print out the image of the profile and cross our fingers while we sketch it from scratch, however I am not confident if I can get it sketched the way it is!
Please help and thanks a lot in advance.
Matt.
Old   October 10, 2005, 03:52
Default Re: Fluent case file........
RoM
Try the export function with ASCII, select the boundary of your airfoil as surface and choose x-coordinate, and y-coordinate from "functions to write". Select the "node loaction" checkbox and write the whole stuff into a file. You probably wont get this imported into your cad but at least you have a coords file to start with.
RoM
Old   October 10, 2005, 09:11
Jason
You can read *.cas files into Gambit (File->Import->Mesh, change the type to Fluent 5/6, and make sure that you pick the 2D dimension). Then you can delete anything you don't need and either model it in 3D here, or export it as an iges file.
The downfall to working from a mesh is that your surface resolution will only be to the length of your mesh size. So if the mesh on your airfoil is relatively coarse, you will never be able to get a more refined model. All you can do from there is to estimate it using a spline through the node locations (in whatever CAD package you pull the node locations into).
Hope this helps, and good luck, Jason
Old   October 10, 2005, 14:01
Matt
Many thanks for the suggestion guys.
I will let you guys know how I get on.
Thanks once again.
Matt.
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 16:46
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
automatic case file loading in fluent calogero FLUENT 8 May 15, 2003 02:48
