Home > Forums > FLUENT
Post - Custom Fiel Function Calculator
Old   October 11, 2005, 04:43
Default Post - Custom Fiel Function Calculator
Michael Bo Hansen
How can I define a User Defined Variable in Fluent like this one: Tstar = (T " T_mean_outlet) I have tried the Custom Field Function Calculator but it is not obvious to me how to use a surface integral value in the calculator directly. Can it not be done?
Kind regards. Michael Bo
Old   October 11, 2005, 06:44
Default Re: Post - Custom Fiel Function Calculator
Sachin
Use define/custom field function (CFF) field function/Temperature/static or total temperature /select you will see it on definition window then by clicking the required formula and values with help of "mouse click" get the custum field function For "T_mean_outlet" define this as CFF as said above and then select the formula and then for post processing do the following; 1) see the "contours/CFF" apply 2) see the surface intigral; this will give you the overall avarage value on surface, find it in TUI write me for further details; Thanks
Old   October 11, 2005, 08:50
RoM
Since you cannot adress a boundary in the custom field function calculator its not possible to define Tstar directly. If you need it only for postprocessing you can get the mean value from the report->surface integral panel and use it in your cff. If you want to monitor Tstar to judge convergeance during iterations you will need an udf.
RoM
Old   October 12, 2005, 01:39
Michael Bo Hansen
that sucks.
Thread Tools
Trackbacks are On
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Force function calculator Anil CFX 0 March 20, 2007 19:45
Function Calculator in CFX 10 Post SKL CFX 2 December 20, 2006 07:29
Could you please help me liugx212 OpenFOAM Paraview & paraFoam 4 December 22, 2005 17:55
