Home > Forums > FLUENT
refreshing contours after x iteration
Old   October 12, 2005, 15:39
Default refreshing contours after x iteration
rachid
Hi again,
How do I refresh the contours monitor after x iteration during iterations?
Old   October 13, 2005, 01:58
Default Re: refreshing contours after x iteration
RoM
You can use the Solve->Execute command panel to update a contour plot. Define 2 commands the first is
//dis/setw X
It will activate the window number X (where your contour plot is)
Second command is
//dis/cont temperature
to display a temperature contour.
RoM
Thread Tools
Trackbacks are On
how to increase "Newton Pressure Iteration Limit" kus CFX 9 April 21, 2013 01:54
snappyHexMesh aborting Tobi OpenFOAM Native Meshers: snappyHexMesh and Others 0 November 10, 2010 04:23
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 23:30
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
