moving wall with grid_motion?
Old   October 18, 2005, 14:03
Default moving wall with grid_motion?
Joerg
Hello i have a problem. i want to move a piston. the piston is in a membrane. so i have to simplify the problem. my problems are the walls next to the piston. they have to move with the piston. one side of the wall is fixed an the other side is moving. i hope you understand my problem. so my question is, which define macro should i use? the define_geom, the define_grid_motion or another? and how should i read the udf. i have problems to understand the example of the udf manual, because there are instructions i could not find in the index. like: NV_D NODE_X(v) NODE_POS_NEED_UPDATE(v) NODE_POS_UPDATE(v) NODE_COORD
i hope somebody can help me.
Thanks Joerg
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 11, 2008 23:23
moving wall and fluid soody FLUENT 3 September 20, 2004 01:37
Values of k & epsilon in the moving wall ghlee Main CFD Forum 1 August 16, 1999 12:42
