heat transfer
Old   October 1, 2005, 16:02
Default heat transfer
enzo
I have a 2D geometry and I want to study temperature profile in solid and fluid.I set wall ( thickness=0) the b.c. between solid and fluid.I'd want to know if I must turn on planar conduction (or it's possible only in 3D geometry?) thanks
Old   October 16, 2005, 02:15
Default Re: heat transfer
Sachin Kulkarni
Shell/Planar conduction is activated only for 3D cases. And there also, it will have any meaningful effect only if the wall thickness is set to some non-zero value.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
