Parallel Performance of Fluent
Old   October 29, 2005, 09:19
Default Parallel Performance of Fluent
Soheyl
Hi
I am running the parallel version of fluent on a cluster of 8 nodes. I want to evaluate the performance (speedup). Is there anybody having suitable case and data files and the speedup they obtained on their system with those files? I want to compare the results.
Thanks
Old   October 29, 2005, 12:02
Default Re: Parallel Performance of Fluent
sai shiva muppur
hi,
it varies from case to case and the optimum no of nodes for best performance depends on the communication between nodes for your case. but its still easy. u can measure it urself. run once on a stand alone m/c and note down time taken for, say 50 timesteps. then repeat it for different no of nodes. remember that number of nodes need not mean a linear boost-up always!
muppur
Old   October 30, 2005, 06:11
Soheyl
I have used this method, and I have obtained the speedup graphs, but I need to compare it with someone else's works. I need somebody that has the same experience, so I can use the same case and compare the results (speedup) with his/her work.
parallel fluent runs being killed at partitioing Ben Aga FLUENT 3 June 8, 2012 10:40
FLUENT parallel performance on 6-core processors BRG FLUENT 2 May 27, 2010 18:21
Fluent Parallel Error Will Humber FLUENT 2 April 3, 2008 14:15
Parallel Fluent Usage ILia Skryabine FLUENT 1 January 19, 2007 08:31
Parallel Fluent on Linux clusters Chengwang Lei FLUENT 3 November 24, 2004 02:05
