October 20, 2005, 11:50 |
!Error creating animation sequence file
I have a sequence file called .\sequence-1.cxa along with a bunch of hmf files. I am trying to play them back and write an animation file. However, I get the following error:
!Error creating animation sequence file: .\sequence-1.cxa Also, if I choose to hardcopy them instead to a jpeg I get errors there too: CX_Hardcopy_Window: error opening JPEG file .\sequence... any ideas? |
October 21, 2005, 04:35 |
Re: !Error creating animation sequence file
I assume that the error message appears when you try to write the frames as jpgs.
If you're working on windows platform, it might be something concerning the location of a .hdi file, I once read a mail about it from fluent support, but I lost it! On unix, it simply doesn't work (at least on my unix system it doesn't work, and fluent support gave up...). You have to create an hardcopy of your frames manually or by a jou/scheme file and then join them with an external application. If you get some error messages when you try to just play your metafiles back in the fluent panel, might be because the .cxa file is corrupted, sometimes it happens...but you can easily open it with a text editor and repair it. The syntax is straightforward. Hope this helps Edi. |
Display Modes | |
tecio compilation errors in latest 1.6.x | rsamuel | OpenFOAM Bugs | 2 | June 25, 2021 08:10 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
