Too high pressure gradient in an emptying case
Old   November 6, 2005, 02:59
Default Too high pressure gradient in an emptying case
Alireza
Hi guys, I'm modeling the emptying of a tank full of methane pressurized up to 300 atm to the atmosphere through a pipe. I used coupled implicit solver with k & epsilon standard model. What is bothering is that almost with all turbulent models I dont reach to a convergent solution for velocities and the residuals oscillate so much around some quantities which is low enough.The solutions are realistic and the mass flow rate converges but the oscillations never fade away. The Mach number is above 1 in some little regions at the end of the tube which means it does not obey the 2nd law of thermodynamics, but i think its negligible. Would you please tell me which solver or turbulent models or parameters I should choose to overcome this situation?!
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 07:26
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
Inputting pressure gradient in Fluent Josyula FLUENT 2 December 23, 2009 07:26
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
