Gradient of a variable
Old   October 26, 2005, 05:51
Default Gradient of a variable
P
I have variable let us say A which is not solved in the fluent but it is kind of related to UDS C which is solved now I would. I would like to compuet gradients of this variable A over the domain. How can I dod so. I know getting the gradients a variable which is solved for is easy but how to obtain the gradient of A.
P
Old   October 26, 2005, 06:08
Default Re: Gradient of a variable
RoM
You can abuse an UDS as memory if you set the diffusivity to (almost) zero and adjust the flux function so it will return zero. The you can calculate A, store it in the scalar and retrieve the gradient from the scalar. See chapter 5.6.3 of udf guide for an example.
RoM
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 09:19
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
