Help with UDF for Hinged Leading and Trailing Edge Deflections
Old   August 12, 2021, 14:59
Default Help with UDF for Hinged Leading and Trailing Edge Deflections
Minnesota
tsprengeler is on a distinguished road
Hi Everyone,
I am new to Ansys Fluent and UDF's but have ample experience in CFX. I need to simulate the motion of a moving leading/trailing edge deflection on an airfoil. I will have a non-rigid body so I know I need to use the Grid_Motion macro. I was wondering if anyone can help me set up the UDF. I need to specify the x location for the motion at 25%c and 85%c for leading and trailing edge respectively. I need to set a max deflection of 6 degrees. I need the amount of deflection per timestep to be specified by a equation of motion which I don't have yet but I will.
If anyone is able to help me with this I would greatly appreciate it.
tsprengeler is offline   Reply With Quote
airfoil, fluent, morphing, moving, udf
Meshing near leading and trailing edge of propeller surajp92 STAR-CCM+ 1 June 1, 2017 01:40
[ICEM] Sharp leading and trailing edge airfoil matters_100 ANSYS Meshing & Geometry 10 April 5, 2016 14:20
Leading edge and trailing edge of an airfoil rotor blade Jun_Milan CFX 0 July 10, 2014 23:07
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 10:42
[DesignModeler] Creating a blunt trailing edge from collapsed leading edge gmd ANSYS Meshing & Geometry 0 March 2, 2012 09:48
