Re:Creating a Face in gambit
Old   October 29, 2005, 11:05
Default Re:Creating a Face in gambit
Fatou
I am trying to create a face between an arc and an aerofoil for meshing purposes.I am using the same method as stated in http://instruct1.cit.cornell.edu/cou...uent/airfoil.I keep getting an error message "cannot make wire with dublicate vertices".I double checked all my vertices and realised that vertex G has the same coordinates as the end vertices of the aerofoil.I tried deleting the end ones but it won't let me delete because it forms part of an upper topology.I just don't know what to do from here.Can anyone help please. Thanks
Old   October 31, 2005, 09:03
Jason
Connect the vertices. In the vertex tools, the connect button is on the top row, second from the right (I think)... it looks like someone is pluggin in two ends of a black extension cord.
If the coordinates are within tolerance, then it will create a single vertex that all the edges share and will automatically delete any extra vertices.
Hope this helps, and good luck, Jason
Old   November 2, 2005, 06:51
Fatou
Hi jason Thanks for the reply but that doesn't seem to work cause am still getting the same error message. Anymore suggestions?
Old   November 2, 2005, 08:24
Jason
All I can say is double check your vertices. If there was another reason why the face creation didn't work, then it would usually tell you.
Good luck, Jason
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
