October 28, 2005, 06:14 |
natural convection
In FLUENT, when we do an open-ended domain natural convection problem, is the "guage total pressure" in the Pressure-Inlet boundary condition equivalent to the Stagnation Pressure at the inlet?
October 29, 2005, 08:32 |
Re: natural convection
Hi Ravi,
When you model an open-ended natural convection problem and the flow is incompressible then the total gauge pressure at the panel of the Pressure Inlet is zero. The latter means that the static pressure difference (difference between the static pressure at the inlet region and the static pressure in a point outside the inlet at the same height where the fluid is motionless )is equal to the dynamic pressure. I hope to help you! Vagelis |
November 8, 2005, 07:08 |
i think it doesnot matter, if it is a incompressible flow, then the absolute pressure is meaningless, we only care about the relative pressure.
regards |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 04:22 |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 04:58 |
natural convection at high Rayleigh | mauricio | FLUENT | 2 | February 23, 2005 19:43 |
Mixing By Natural Convection Processes | Greg Perkins | FLUENT | 0 | February 12, 2003 18:40 |
