sensitivity analysis
Old   November 3, 2005, 04:42
Default sensitivity analysis
Silvia
Hello everyone! My Fluent base-case dealing with coal combustion has reached convergence. Now I would like to make sensitivity analysis: I have to vary the primary air flow rate in order to analyse the effect on combustion process. I don't know if I have to reinitialise the solution every time I change the mass flow rate or if I can start the calculation from my base case. Thanks for your help! By Silvia
Old   November 3, 2005, 04:48
Default Re: sensitivity analysis
rom
If your boundary conditions dont vary too much its always a good idea to use an existing solution as starting point for a new calculation. Change the air mass flow rate an continue the calculation.
RoM
Sensitivity Analysis - Grids Not Asymptotic Marc FLUENT 2 November 8, 2017 06:35
CFX Ansys convergence(RMS or Max Residual) farianka CFX 5 November 21, 2010 05:25
Grid sensitivity analysis darookie CFX 2 August 25, 2009 09:00
What exactly is a sensitivity analysis? Josh CFX 3 August 19, 2009 09:18
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
