symmetric flow around fuselage
Old   November 3, 2005, 05:50
Default symmetric flow around fuselage
Christoph
Hi folks, I´m trying to simulate the flow around a fuselage. As long as I run it as a whole 3D-model, everything works fine, as soon as I try to break it down into a symmetric problem, I get stucked. Depending on the mesh-resolution, I´m sometimes not able to even generate a volumemesh with Gambit (seems to me, that Gambit might have a problem to fit a mesh between the high resolution on the fuselage and the lower resolution on the symmetric plane). When I run the symmetric simulation, I get floatingpoint errors, all residuals go up, but the continuity stays at 1 ? My BC´s are velocity inlet, outflow, symmetry, walls(shear stress=0)and the normal wall on the model. I tried to set the pressure to zero and used the axis boundary cond. instead of outflow and symmetry, but without success. Has anyone suggestions - might be a stupid beginner fault?
Thanks,
Christoph
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
symmetric flow lehoang_mai FLUENT 6 July 27, 2010 06:56
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
