-   -   highly compressible flow : Fluent Error Message (http://www.cfd-online.com/Forums/fluent/38487-highly-compressible-flow-fluent-error-message.html)
Amit Shrestha November 3, 2005 13:59
I have a 3D model (with hybrid meshing) of an aerofoil. When I run it in fluent under Coupled-Explicit Solver and Compressible condition (density-ideal) the following error message comes up.
Error: Specific_Heat_by_T_integral: invalid lower bound, T0 <= 0 Error: Object: ()
I would be grateful if anyone could help me with this.
Many thanks, Amit Shrestha
Jason November 3, 2005 14:05
Re: highly compressible flow : Fluent Error Messag
It sounds like your temperature is going to 0K. If this is happening before iterating, then it's probably your boundary conditions. If this is happening while it's iterating, then you should check your limits for temperature (Solve->Controls->Limits) and make sure you're not letting your temperature reach 0K.
Good luck, Jason
Amit Shrestha November 4, 2005 04:28
Thanks Jason,
I will look into it. But I am quite confused since the possiblity of the temperature going to 0K is quite remote since I am working in the region of 800 to 2000K.
Amit
Ahmed November 4, 2005 08:33
Check underrelaxation for pressure, reduce it to say 0.01 then increase it as the solution progress
Libing November 11, 2005 00:31
check your boundary conditions and operating pressure. Make sure they are correct. inconsistent pressure setting could lead to this warning.
