October 21, 2005, 06:35 |
Fluent UDF's / dynamic meshing errors
Good morning all
I am trying to model an aerofoil starting motion abrubtly. I have written a UDF which basically says if time < t1 then velocity = 0 else if time < t2 then velocity = x else velocity =0 so that should start off with nothing moving. The aerofoil should then move a short distance and then stop. The problem is, when I try to run the problem, I eventually get an error message. Sometimes this is 'Segmentation violation', sometimes 'Bus error'. I have a feeling that this is because the remeshing process cannot cope - sometimes the error is due to negative cell volumes. Can anyone give me a hint as to how I can solve these problems? Or if anyone can think of an easier way to model the problem, that too would be helpful. Thanks all, Peter |
October 21, 2005, 10:12 |
Re: Fluent UDF's / dynamic meshing errors
I think I found the solution. Playing around with the dynamics mesh parameters - especially minimum and maximum cell volumes - and using very small time steps (~0.005s) seems to elimate the problem.
Peter |
November 6, 2005, 03:36 |
I think you should apply for DEFINE_CG_MOTION ,The model might be useful for you
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
FLUENT Journal File Errors | cfd23 | FLUENT | 4 | July 14, 2010 04:12 |
Dynamic Mesh Can not Be Used in FLUENT 12.0 | lzgwhy | ANSYS | 1 | April 18, 2010 18:19 |
Using compiled UDF:s in different Fluent versions | S H | FLUENT | 1 | September 12, 2007 03:40 |
dynamic meshing option | arehman | Main CFD Forum | 4 | June 27, 2004 02:55 |
