How to check for Grid independance?
Old   November 8, 2005, 03:21
Default How to check for Grid independance?
Ravi
How to check for grid independance in FLUENT. mine is a steady state case of natural convection in vertical tube. Ravi
Old   November 8, 2005, 04:00
Default Re: How to check for Grid independance?
Christof
I think you ought to run the simulation on different, increasingly refined grids and evaluate the change in important parameters such as pressure and velocity
Old   November 8, 2005, 11:14
Jeremy
Just an addition here. You may want to do plots of the some parameters, such as shear stress, temperature distribution, velocity distribution and save them for each mesh size. Then compare them. Also look at comparing the fRe values and also compare them to literature data if you have any.
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Cell check and Boundary check errors AB Siemens 4 October 28, 2004 13:04
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
