UDF Doubt
Old   November 10, 2005, 05:26
Default UDF Doubt
Kulasekharan
Iam running fluent in Sun OS Server in my university. when compiling a UDF (which ran successfully in Windows based fluent) iam facing a problem. Fluent tells syntax error in the first line itself.
iam using interpreted mode in reading the UDF.
i need help regarding whether any syntax has to be changed for making the UDF run compatibly in Sun OS 5.9.
Thanks in advance Kulasekharan N
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
flapping wing udf a serious doubt doctsh Fluent UDF and Scheme Programming 0 February 17, 2011 12:05
A doubt in linking the UDF to Fluent6.2 - SunOS Kulasekharan FLUENT 1 November 22, 2005 15:32
DEFINE_SOURCE UDF doubt ramesh FLUENT 1 May 29, 2004 07:13
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
