Periodic pressure gradient.
Old   December 15, 2012, 01:24
Default Periodic pressure gradient.
A7A
AHMAD
A7A is on a distinguished road
I am modelling a 3d periodic flow of air in a tube with wire coil insert (using relizable k-e model), and after 1500 iterations i get a good results of Nusselt number compared to the experimental results, but the friction factor(which is computed this way: f=(dp)/(0.5*density*velocity^2*(length/tube diameter))
is so high compared to the experimental results.
Could you give me any advice about this problem.
Thank you in advance
A7A is offline   Reply With Quote
Old   December 15, 2012, 08:32
A7A
AHMAD
Any ideas?
Old   December 25, 2012, 03:13
A7A
AHMAD
Could you give me any solutions, untill now i couldnt manage to solve this problem.
Thank you in advance.
Old   January 15, 2013, 08:38
Kamu is on a distinguished road
Which value of dp do you use for calculation of f? the correct value should be the pressure gradient under the periodic boundaries panel, you have to multiply it by the length of your tube.
Kamu is offline   Reply With Quote
Old   January 15, 2013, 10:27
A7A
AHMAD
Thank you Kamu for your reply , but there is no need to multiply dp by tube length because its divided by length in f correlation.
Old   November 24, 2021, 01:18
Default Cfx
amir hossein salati
A.H.S is on a distinguished road
Hi, this way had totally help me with this kind of problem but what about CFX. how can I estimate pressure gradian between two periodic zones. I first guess is to use CFD-Post but with what variable?
A.H.S is offline   Reply With Quote
how to get pressure and pressure gradient using UDF Honglin Fluent UDF and Scheme Programming 0 May 24, 2012 06:47
Pressure gradient/ Skin friction in periodic flows chivaee Main CFD Forum 0 May 17, 2012 23:13
Pressure BCs or Periodic BCs for model of frost on vertical surface? andy.eco FLUENT 2 March 26, 2010 02:02
Inputting pressure gradient in Fluent Josyula FLUENT 2 December 23, 2009 07:26
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
