Pressure drop
Old   November 7, 2005, 11:17
Default Pressure drop
Madhukar Rapaka
Hi I am simulating the flow(2D) in a fin and tube heat exchanger. (The geometry consists of a long rectangular tube with three rows of cyllinders placed perpendicular to the flow) I want to calculate the pressure drop between two surfaces. Can someone tell me , how Fluent calculates the pressures. I have gone through the User's guide and i found that fluent applies some corrections in calculating the pressures.(Ptot.=Pop.+Pgauge) I am using incompressible flows. So can anyone tell me how Fluent calculates the pressures.
thank u
Old   November 10, 2005, 01:22
Default Re: Pressure drop
Murthy
Madhu,
In Fluent, static pressure is your local pressure and operating pressure you have to specify in the fluent panel. Don't get confused with static head,static pressure those are completely two different parameters in fluent.Hope it clears you.
Old   November 10, 2005, 03:05
Madhukar Rapaka
Hi
I would like to know how the pressure is calculated in FLUENT...i mena which formulas FLUEN uses to do this
thanks in advance
Old   November 12, 2005, 11:58
Murthy
Fluent offers different pressure-Velocity coupling techniques like SIMPLE,SIMPLEC,PISO to calculate local pressure (Static Pressure).
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 14:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 04:47
