October 3, 2004, 17:09 |
Gambit error: Cannot find exceed x server
I have installed Exceed 7.1 and Gambit 2.0 on my PC operating with WinXP. This error message appears whenever I tries to run gambit "Unable to Find Exceed XServer" or "Unable to open display".
Tried using the following workaround posted in Hummingbird website but the same error still persists. Open up Control Panel Double click on System Click on the Advanced tab Click on the Environment Variables button Under User Variables click the New button In the Variable text box type: DISPLAY In the Value text box type: computer_name:0.0 (where computer_name is the actual name of your computer) Click OK. Any advice how to resolve this? Thank you. |
October 3, 2004, 19:17 |
Re: Gambit error: Cannot find exceed x server
install complete verson of exceed with selceting complete ans also make it common
October 4, 2004, 02:46 |
You just install the exceed again, and give personal installation or complete installation. Then it will work. And if you have gambit 2.0.4 version, install it. It will not give any problem with exceed 7.11 version. I hope it will work
October 4, 2004, 08:59 |
Tried re-installing exceed and gambit but still didn't work...
Thanks for the advice though |
October 4, 2004, 09:38 |
it should work
did u set envirment variable |
October 4, 2004, 11:41 |
Try with gambit 2.0.4 version. And give the license path correctly.
Venu Gopal |
September 10, 2011, 11:43 |
jbr
Rep Power: 14 |
hi all i have the following error while trying to open the gambit, can u please tell me hoe do i fix it.
gambit XIO: fatal IO error 0 (Winsock Error) on X server JONBONRAKI-PC:0.0 after 0 requests (0 known processed) with 0 events remaining. |
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 | pdilly | FLUENT | 23 | April 2, 2016 12:10 |
Gambit Default Working Directory | Virgil Howardson | FLUENT | 5 | December 19, 2009 06:13 |
Athlon 64 Gambit Compatibility? | Derick | FLUENT | 3 | January 17, 2006 17:28 |
exceed for gambit 2.2 | steve | FLUENT | 4 | July 26, 2005 09:09 |
Gambit error : Unable to find Exceed X Server | Jarod | FLUENT | 2 | November 4, 2004 06:41 |
