Rendering
I'm trying to visualize the results from a 3D analysis but a error message appears everytime: render-generic: No rendering surfaces have been set. I've already try the setup of the Display options, but I couldn't find any improvement. If somebody have idea what is wrong, please let me know your advise. Thanks. |
Re: Rendering
Hi!
Are you sure you have selected the proper surfaces in the surfaces list? /Henrik |
Re: Rendering
Hi Rogelio,
In order to visualize your results you must select the surface. For eg. In the Display panel,click contours select velocity/pressure or anything else you want and then in the surfaces list select the surface for e.g. default_interior etc. Hope this helps! VJ |
