Rendering
Old   November 14, 2005, 10:57
Default Rendering
Rogelio
I'm trying to visualize the results from a 3D analysis but a error message appears everytime:
render-generic: No rendering surfaces have been set.
I've already try the setup of the Display options, but I couldn't find any improvement. If somebody have idea what is wrong, please let me know your advise. Thanks.
Old   November 14, 2005, 13:03
Default Re: Rendering
HS
Hi!
Are you sure you have selected the proper surfaces in the surfaces list?
/Henrik
Old   November 17, 2005, 14:26
Vijaykumar Sathyamurthi
Hi Rogelio,
In order to visualize your results you must select the surface. For eg. In the Display panel,click contours select velocity/pressure or anything else you want and then in the surfaces list select the surface for e.g. default_interior etc. Hope this helps! VJ
Rendering your CFD results - general discussion cfdnewbie Main CFD Forum 55 January 17, 2019 13:06
Ansys CFD + rendering farm nolga ANSYS 3 July 1, 2011 13:40
Paraview rendering quality spurwonofjp OpenFOAM 2 May 25, 2010 13:16
[OpenFOAM] Volume rendering in paraview33 aunola ParaView 0 October 4, 2008 15:35
Math rendering default changed to always PNG Jonas Larsson CFD-Wiki 0 December 10, 2005 10:00
