November 14, 2005, 13:57 |
interface
After initial the model, the system tells the following warn.
WARNING: Unassigned interface zone detected for interface 6 Error: Init_Flow: unassigned interface_zones Error Object: () What happen? How to change it? Thank you! |
November 15, 2005, 02:58 |
Re: interface
If ur interface contain periodic surface; check on periodic in interface panel.......... If interface contain two different fluids or solid-fluid interface, plz check on coupled in interface panel. hope it will be helpful..........
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 02:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
