Home > Forums > FLUENT
Using UDF
Old   November 15, 2005, 22:15
Default Using UDF
Vidya Raja
I have an equation for unstaedy velocity. It is as follows:
Q = 0.35 + 0.35* sin(2*pi*0.5*t)
I wrote the following code in C to hook it to fluent:
unsteady.c UDF for specifying a transient velocity profile boundary condition ************************************************** ************************************************** ******/
#include "udf.h"
DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; real t = CURRENT_TIME;
begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = 0.35 + 0.35* sin(2.*pi*0.5*t);
} end_f_loop(f, thread) }
But when I hook it to fluent, it displays an error that says
parse error. What does this mean? Is there something wrong in my C code? How do I hook it to fluent?
Any help/ suggestions are highly appreciated.
Thanks, Vidya
Old   November 17, 2005, 04:12
Default Re: Using UDF
RoM
Dont interpret your udf from a directory which name has spaces like in "c:\my documents". This will give a line 1: parse error. Use M_PI instead of pi. Hook your udf in the bc panel for the velocity inlet.
Hope it helps, RoM
Old   November 17, 2005, 10:55
Vidya Raja
Hi, Thanks for the help, but can I make the Desktop my working directory and then store the C file, and the case and data files on the desktop and work from there? If not, could you please tell me step- by- step how to do i
I use the compute in my lab and so temp files are deleted every day.
Sorry for bothering you.
Thanks, Vidya
Old   November 17, 2005, 11:35
RoM
I have not found a way to work around this "no spaces in directory names allowed" feature (someone could call it a bug). You will have to interpret your udf from a directory with no spaces in name. Once the udf is interpreted, hooked and the case is running it doesnt matter if the file is deleted. Fluent will continue running and as long as you have a backup of your source file you should be fine.
RoM
Old   November 17, 2005, 13:56
Vidya Raja
Thanks RoM.......... it worked. Thanks a lot, once again.
Vidya
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
Dynamic Mesh UDF Qureshi FLUENT 1 December 2, 2009 01:27
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
