Fluent, Aeroelasticity, Moving Mesh
Old   November 5, 2005, 11:18
Default Fluent, Aeroelasticity, Moving Mesh
Andrew P Clarke
My problem is that I'm trying to model the flapping wings of an ornithopter (ie flapping wing model aeroplane). The ornithopter wings consist of a leading-edge spar which flaps up and down, attached to which is a flexible wing surface. The wing surface deforms due to the aerodynamic forces either side of it.
I want to model this in Fluent, but I don't know how.
The difficulty is, firstly getting the thing to flap, and secondly, getting the wing to deform.
I'm only a poor student with no hope in getting this show on the road without help.
Any advice would be hugely appreciated.
Cheers.
Old   November 8, 2005, 21:39
Default Re: Fluent, Aeroelasticity, Moving Mesh
gaohongliang
the thing to flap is realized by means of DEFINE_CG_MOTION the wing to deform is by using DEFINZE_GEOM
Old   November 16, 2005, 07:06
Andrew P Clarke
I cannot find the funtion DEFINZE_GEOM in the help. Can you check that it's the correct function, please?
Thanks.
Old   November 16, 2005, 07:23
Andrew P Clarke
Actually, scrap that, I think you meant DEFINE_GEOM.
Thanks for your help, much appreciated!
Transport mesh from ICEM CFD, to Fluent, to Sysnoise Wieland FLUENT 2 April 15, 2012 06:28
mesh missing after import in fluent morteza08 FLUENT 0 July 23, 2010 02:22
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
C4 = 1 for Moving Mesh Xobile Siemens 2 January 18, 2005 05:22
