drawing curved line,plotting skin friction lines
I'm using Fluent 6.2. I'm trying to draw a line on the blade. I actually wanted to draw a curved line but in the function panel for creating line, only straight line can be drawn. May i know how to draw a curved line on a wall surface (which is curved)? I need to do that as i want to do a XY plot of the static pressure along that curved line on the blade.
I'm also trying to plot skin friction line on wall surfaces. In the function panel for plotting pathlines, i can only obtain the pathline but not the skin friction lines on wall surfaces. How do I do that in Fluent??? Regards |
Re: drawing curved line,plotting skin friction lin
hi,
you can actually draw a curved line that follows the shape of an exesting surface at a certain position. To do so, you have to create an "iso-surface" (from the dropdown list in "surface"). Choose surface of constant "grid" (you can draw the line at a constant x or y or z value, according to your geometry or surface of interest location, you have to specify the value in the iso-value box). In the "from surface" box you have to select the surface around which you want to draw the curved line. Hope this helps. Thérèse. |
