-ve value of static pressure
Old   November 23, 2005, 00:45
Default -ve value of static pressure
Anu
Anybody could help me on understanding what is meant by static pressure in Fluent? Certainly it doesn't seem to be the value of RHO*g*h. When I get the XY-Plots for static pressure it shows negative values. I am also not able to understand the contour plotting of static pressure.
Dynamic pressure seems to be alright and having value of 0.5*RHO*V*V.
Please help me in this regard Thanking you Anu
Old   November 23, 2005, 05:18
Default Re: -ve value of static pressure
bharat
Check out the operating pressure
simple model, difficult outlet Eric CFX 7 May 23, 2014 08:13
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
How to achieve constant static pressure in inlet? Zou Jianfeng FLUENT 0 October 21, 2008 01:55
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
