Mesh Quality at the Interface
Old   November 23, 2005, 10:32
Default Mesh Quality at the Interface
Can Atli
Hello All,
My question is about the meshing with tetragonal elements. Why do the tetragonal elements yield poor mesh qualities, even if you are meshing a very simple geometry like a cube?
I have a complex 3d geometry, which i divided into 3 volumes. The two volumes were meshed with hex elements, no problems, perfect quality. But, the remaining volume (the one with narrowings, fillets, etc) had to be meshed with tetragonal elements having poor quality. The quality is even worse at the interface between hex&tet elements even if the element sizes match.
I tried to perform a segregated, steady state flow analysis, but could not achieve convergence, possibly because of this mesh problem.
What do you suggest? Thank you for your assistance,
Can
Hi Julie,
sounds ok. A skewness of 0.94 is not yet a disaster. The grid resolution should be ok to give an idea if the flow, if there are no recirculation regions or so. What about your Reynolds number? Have you looked at your Y+ values?
Why unsteady state? Is your flow unsteady? If you are lookinf for a steady state solution, you should use the steady solver. If your flow is unsteady, then how did you initialise your solution?
So you used a Tet-mesh all over? Can't you split the volume into smaller parts an mesh most of the geometry using a hex-mesh?
kind regards, Laika, still orbiting
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Complex Interface Mesh Jonny6001 STAR-CCM+ 3 February 16, 2011 04:59
Improve Mesh quality - airfoil simulation Lukas84 STAR-CCM+ 4 July 6, 2010 10:07
Moving interface patch using mesh subsets lr103476 OpenFOAM Running, Solving & CFD 0 January 10, 2008 16:14
