record a variable in UDF
Old   November 22, 2005, 01:25
Default record a variable in UDF
reto
hello
i have an unsteady problem with an UDF. how can i record a variable by time in a file, to get a list? at the moment i use fprintf but i get only the value of the last time step.
thanks
reto
Old   November 22, 2005, 15:30
Default Re: record a variable in UDF
Zhang
My suggestion:
1. Define a DEFINE_ON_DEMAND subroutine. In this subroutine you open an output file. Something like this,"ofp=fopen("out2.txt","w");"
2. Define a DEFINE_EXECUTE_AT_END subroutine. This subroutine will be executed at the end of each time step. In this subroutine your output the value of desired variables. e.g. "fprintf (ofp,"%e\n",variablename);"
3. Define another DEFINE_ON_DEMAND subroutine. In this subroutine you close the output file. "fclose(ofp);"
4. Please include,
#include "stdio.h"
#include "udf.h" and define,
FILE *ofp; at the beginning of your source code file.
5. Before you start the iteration, run the first subroutine through "Define -> User-Defined -> Execute On Demand...". Then iterate. Once the iteration finished, run the third subroutine through "Define -> User-Defined -> Execute On Demand...".
6. Hope it works. Good luck!
Zhang
Old   November 23, 2005, 04:01
reto
many thanks for your suggestion, it works!
reto
Fluent UDF urgent! Variable reaction rate natantyt Fluent UDF and Scheme Programming 8 October 17, 2021 03:35
Do I need to use UDF to get time-averaged variable? ivanbuz Fluent UDF and Scheme Programming 0 August 11, 2009 14:26
Variable for AVERAGE VELOCITY, Pressure etc. in UDF? aam Fluent UDF and Scheme Programming 0 May 15, 2009 05:21
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
Yplus UDF variable Matthew Brannock FLUENT 0 June 23, 2003 03:41
