May 16, 2014, 11:16 |
Laminar or turbulent flow
TAK
Rep Power: 12 |
Hi friends. I know if the Reynolds number is very low (<4300 in case of air) then flow is assumed as laminar. I simulated flow around a plate at Re=3000, i got valid results with laminar model. Now, if the plate is oscillating or plunging then i think the flow field will not remain same. I have doubt that the flow is still assumed as laminar or there will occur turbulence? How to judge that there is turbulence in flow in such case? Kindly help
May 16, 2014, 11:37 |
Rep Power: 15 |
As far as I know the incoming flow will be still called laminar and due to the oscillating geometry the flowfield will change.
May 16, 2014, 11:45 |
TAK
Rep Power: 12 |
thanks for your reply. Do you mean that i should assume the same flow conditions and no turbulence model? If yes then it means that disturbance in upstream laminar flow will not bring turbulence in flow. Am i right?
Display Modes | |
Do formula for Laminar and Turbulent Flow Calculation formulae change with Fluid | Parag Gadgil | FLUENT | 0 | June 19, 2012 08:07 |
Turbulent / laminar flow | broken | Main CFD Forum | 0 | May 9, 2012 07:44 |
Can I use turbulent model to solve a laminar flow? | nikhil | FLUENT | 5 | February 1, 2011 11:42 |
Turbulent viscosity in Laminar Flow | Mike | Main CFD Forum | 8 | April 12, 2010 12:40 |
Reynolds and Turbulent flow | Frederic Dubinski | CFX | 5 | October 21, 2004 05:12 |
