DPM concentration macro??
Old   November 29, 2005, 13:24
Default DPM concentration macro??
Yurong
Could you please help me with DPM concentration macro? I cannot find any information in Fluent help files. I would like to know how to use it in UDF and if there is an example for using this macro.
Many thanks in advance.
Old   November 29, 2005, 17:30
Default Re: DPM concentration macro??
alex
what do you need about DPM macros? May be, I would help you because I have solved some problems relationed with DPM macros.
Old   November 30, 2005, 02:51
RoM
C_DPMS_CONCENTRATION(c,t)
RoM
Old   November 30, 2005, 04:13
Yurong
Alex, thanks for your help. I would like to define "thermal conductivity" as a function of the particles concentration. Therefore, I would like to use DPM-concentration macro. I will be very grateful if you can provide some examples to me because I am even not familiar with UDF yet. Thanks again.
RoM, many thanks for your information.
Old   November 30, 2005, 16:02
alex
If you want, I can help you with your problem but I think that if you need any thing about DPM macros, the best way is with several messages, is it a problem for you?
The process to create any UDF is very jealous. First you must identify how many and which parameters do you need to elaborate your UDF. Next to it, we selected the best way to create the C code. Previous to this, you should have access to Visual C or any C compiler program.
Just do it, and when you are ready, send me a message to continue, ok?
regards Alex
Old   December 1, 2005, 08:45
Yurong
alex, you are so nice. Thanks a lot for your help. I have already made some progress with my work with UDF. If I come across any difficulties, I will ask for your help again.
Old   December 10, 2005, 11:31
Yurong
Could you please tell me some macros in Fluent including the parameters used in calculating Thermophoresis force, Brownian force, Lift force etc. ? I would like to use udf to calculate these forces. Many thanks.
Old   July 15, 2010, 04:22
Default effective conductivity in dpm macros
mvf
maissam vahidi
mvf is on a distinguished road
Hi dear friend
I am working on a new method for nanofluid heat transfer calculations
if you find a good way to solve your problem, pls send me a simple code for dpm conductivity definition. do you know, what macro is used for particle conductivity in dpm approach?
REGARD
mvf is offline   Reply With Quote
Old   May 3, 2011, 16:27
amir
amire is on a distinguished road
hi alex i have some problem about DPM udf for modeling nanofluid could u help me? thank u
amire is offline   Reply With Quote
Old   November 16, 2011, 23:27
massoud
massoudepsilon is on a distinguished road
Hi Yurong,
I am wondering if you could solve the problem of calculating dpm concentration. I have to calculate it amd I do not know how I should use C_DPM_CONCENTRATION(c,t) macro exactly,
I will be grateful if you can help me
Bests,
Massoud
massoudepsilon is offline   Reply With Quote
Old   November 16, 2011, 23:30
massoud
Originally Posted by RoM
;126569
RoM
HI Rom,
could you tell me that How I should use this macro please?
Bests,
Massoud
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
URGENT - DPM Macro for custom bc cfd-user FLUENT 2 July 21, 2008 11:26
dpm concentration HK FLUENT 0 March 6, 2008 05:44
DPM concentration you FLUENT 0 May 28, 2001 10:24
DPM Concentration you FLUENT 0 May 23, 2001 03:59
