Home > Forums > FLUENT
I have some problem about Compressible
Old   November 29, 2005, 20:15
Default I have some problem about Compressible
Cruger
I doo my research about jet flow that have velocity inlet about 300 m/s and temp inlet about 900 Kelvin. My model is still on 2D. I set the top edge to be wall and outlet to be pressure outlet but it's not work. Do u have some tecnique to tell me? Please I know this maybe easy for u but I just use Fluent program for the first time... Hope to see ur reply
Old   November 30, 2005, 03:51
Default Re: I have some problem about Compressible
Ahmed
1- What do you mean by "I set the top edge to be wall"
a wall is a wall, with no slip boundary condition. 2- If this is your first time using FLUENT, it is a good idea to start by some tutorials?
Old   November 30, 2005, 05:52
Cruger
Anyway, I asked my supervisor for some advices but I get quite not good result. I used Coupled Solver.
2 I enabled energy eqn. 3 I chose K-epsilon 2eqn+Reallizable 4 I chose Ideal gas of air. 5 It's quite difficult to explain my geometry but It's so basic. 6 I started courant number(Solution Controls) at 0.5 7 when I run it, I think I got a not good result.
Please Help me!!! leave me ur e-mail, I will send picture of geometry to u.
But u have any advices, don't hesitate to post it.
, Cruger
Old   December 1, 2005, 10:52
Bob
Try to use mass flow or pressure inlet.
Old   December 5, 2005, 08:05
Mahesh Masurkar
ya, use Pressure inlet. Assuming Ma=1 at the inlet, give Po & To. Put a very fine mesh in the jet region. Use low relaxations for pressure.(0.1-0.15).
Hope this will solve ur issue.
Thread Tools
Trackbacks are On
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
CFD-ACE compressible flow convergence problem DelphineL Main CFD Forum 1 October 21, 2009 05:50
Problem with LaunderSharma compressible turbulence model wrong formulation luca OpenFOAM Running, Solving & CFD 4 July 3, 2006 06:24
Problem calculate Y in compressible turbulence model luca OpenFOAM Running, Solving & CFD 5 June 1, 2006 05:53
momentum under-relaxation for compressible flow with SIMPLE Mihai ARGHIR Main CFD Forum 0 April 7, 2000 04:58
