November 29, 2005, 22:26 |
ANSYS mesh to FLUENT/GAMBIT
Dear researchers,
I like to ask you how to import files from ANSYS to FLUENT/GAMBIT. I want to take vertex,edges,surface,mesh from the ANSYS to FLUENT.I already tried with *.dbs file to GAMBIT.If possible to import in Fluent or Gambit.Please suggest idea. Pillai(TPU) |
November 30, 2005, 21:59 |
Re: ANSYS mesh to FLUENT/GAMBIT
hi,Pillai.
i usually export the archive files(*.cm) from ansys, and import them to fluent. fluent change the components into the surfaces and zones.(node comp->surface, elem comp->zone) hope it helps. |
December 1, 2005, 06:48 |
Thank you nan,
One more question.I that case Is it possible to define the boundary condition and name it inside FLUENT? Becos In GAMBIT we do that in defining boundary condition and then transfer it to FLUENT.Also we change it if we want in FLUENT. But what do you comment about this problem? Pillai(TPU) |
December 1, 2005, 06:56 |
Dear Mr.nan,
I tried it in that way it is not working out.If possible can anyone tell how to change those file from ANSYS to GAMBIT ? |
December 1, 2005, 09:21 |
I often do it the other way around. I export from FLUENT into CFX. I use the file format CGNS, and it works super. - Michael Bo
December 1, 2005, 23:06 |
hi, Pillai.
have you tried it on 2d fluent? if so, try it on 3d. and gambit failed to import 2d-mesh as you stated. i don't know the direct way to import 2d-mesh from ansys to fluent. maybe you can export it from 3d fluent to gambit. sorry. or aren't there too skewed elements in the mesh? sometimes reversed elements stop the import process . and michael, don't you tell me your way can be export the mesh with its boundaries and zones? thank you. ps. on boundary condition, fluent can define them. |
December 18, 2005, 08:18 |
Export .cas file from Fluent to Gambit
I lost the mesh file of gambit. I have a .cas file for fluent. Can anybody help me in exporting .cas file back to gambit and obatining mesh file, please.....
January 2, 2006, 21:59 |
Re: Export .cas file from Fluent to Gambit
ok go to gambit.do import mesh.fill the panel u get.2d/3d for dimension.select fluent 4/5 ... hope it works
regards Rashmi |
Display Modes | |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Problem importing GAMBIT mesh to Ansys geometry | David G. | CFX | 0 | June 19, 2005 07:01 |
