December 3, 2005, 06:19 |
MUSIG model
hi
does any one know what is MUSIG model for drop size distribution. if anyone has articles on this plz fwd. Thanks Rashmi |
December 3, 2005, 14:56 |
Re: MUSIG model
MUSIG model was first initiated by Simo Lo in ADMIRE project sponsored by European Union collectively known was BRITE EURAM Project. SO this all about MUSIG model. It has two parts Break up and Coalescence by Luo and Svendsen (1996) and Prince and Blanch (1993) for coalescence model. Yes the models are valid for Drops. CFX series had it for along time and still has it. The latest version CFX 5.7 has it. There is a large literature about this model u can figure them by doing simple literaure search on Science direct, Compendex.... or even Google. Just go and type ADMIRE OR MuSiG model. 'KP' Wht gerometry you are working on????
December 4, 2005, 22:02 |
Re: MUSIG model
hi thanks
iam modeling on drop size distribution of oil-water dispersed flow in horizontal pipe. do u have any idea about how to go with this in fluent6.2 thanks again regards Rashmi |
December 5, 2005, 08:42 |
Re: MUSIG model
Point to keep in mind that flow has to be bubbly regime and for horizontal pipe I guess it is difficult to get. 6.2 does not have PBE. KP
December 6, 2005, 00:00 |
Re: MUSIG model
but i have a tutorial of fluent for bubble column in that they have used the PBE..then which ver of fluent has PBE. u mean u cannot simulate bubbly flow in horizontal pipe??
December 6, 2005, 09:05 |
Re: MUSIG model
Yes bubble column eg has PBE no doubt. I meant to say that in the case of horizontal pipe u have to look for experiemental cases where the regime is bubbly flow. I hope this helps. KP
DO NOT UPGRADE YOUR CURRENT VERSION OF FLUENT. AS I "PRESUME" YOU ARE ON 6.1.22 BUT IF YOU GOT TO 6.2 U "MAY" ENCPUNTER SOME DIVERGENCE WITH THE SAME CODE.Population balance is ported to FLUENT 6.2 as well in the form of UDF. However it is not yet released for the academic institutes. |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 19:13 |
Musig Model in CFX 5 | Hui | CFX | 0 | September 16, 2005 01:46 |
