dpm spray into open air
Old   December 1, 2005, 19:14
Default dpm spray into open air
kev
hi i got a problem. My domain is 2D-axisymetric rectangular domain 0.3x1.2metres to use a pressure-swirl injector model. I use inlet/outflow and axis and wall BC's. I set velocity = 0 since it is still air and initialize for turbulent flow since the dpm injection will cause some turbulence around the injection. Solution converges immediately since there is nothing to calculate for v=0. When I introduce the DPM by pressure swirl model with massf/r= 0.001kg/s (too high? this is data from experiments) the calculations is very unstable. I use two way coupling which, I am thinking causes the DPM momentum source terms to push the continuous phase along and cause reverse flow since there is no velocity inlet. I was wondering does anyone know how to get around this? Should I just solve it for unsteady? Or try different BC's? Or should I have velocity flow even though it doesn't make sense when I am comparing with spray into still air.
Thank you for ur time
Old   December 3, 2005, 02:52
Default Re: dpm spray into open air
nasser
use Pressure outlet in out flow use very very small velocity in initialization bye
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
DPM Particle types, Spray Dryer Mohsin FLUENT 1 August 2, 2011 21:26
how to set the relative humidity of air in DPM saturn FLUENT 0 April 17, 2009 05:17
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
