Rotating objects in flow using MRF
Old   December 5, 2005, 13:20
Default Rotating objects in flow using MRF
Kyle
I asked this questions a few days ago but I do not think I was clear enough. I am trying to model flow over a rotating object suspended in a uniform flow. This is a diagram of the setup I am using:
http://kwalker.ms11.net/cfd.GIF
I set the angular velocity of Zone 1 to the speed I want the object to rotate. The wall is set as a moving wall with zero angular velocity with respect to adjecent cells. This appears to work well with a very low angular velocity but gives me an answer that is obviously incorrect if I make the angular velocity above about 10 rad/sec. It also has a hard time converging with a high angular velocity. This seems to me to be very similar to the centrifugal blower example, and that works for very high angular velocities. Is there any obvious reason why my setup should not work?
Old   December 5, 2005, 19:29
Default Re: Rotating objects in flow using MRF
thomas
Aren't you in turbulent regime over 10 rad/sec
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 08:53
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Rotating sphere in a turbulent flow kpsl OpenFOAM Pre-Processing 0 November 27, 2010 08:50
flow below a vertical rotating cylinder hani Main CFD Forum 1 October 9, 2002 13:28
Multiphase flow and MRF Yenni Chiu CFX 3 July 19, 2001 11:06
