Skin friction factor
Old   December 8, 2005, 04:36
Default Skin friction factor
Ali
Hi all, I have reached a very big friction factor of order 2000 in modelling the highly compressible flow with a velocity of order 400 in a tube!! Is it possible? Have anybody encounterd such problem? Is this friction factor defined by: Wall shear stress/((1/2)rho*u^2)? Thanks alot
Old   December 10, 2005, 09:49
Default Re: Skin friction factor
samir laouedj
yes i have a problème with a friction coefficient. the friction coefficient is to 0.1;0.2;0.3... but 400 dont friction factor about 2000 but the problems is in the order of the velocity inlet, 400 is big you know how mach number order with 400m/s ??? yes, the friction factor is defined by Wall shear stress/((1/2)rho*u^2). contact me along.
Old   December 11, 2005, 03:25
Ali
Hi, I have to say that the velocity inlet isnt of order 400, but it reaches this maximum value through the pipe while the mach number is almost 1 and the flow chokes. The friction factor is so high at these parts of the pipe where the velocity is rising. The velocity inlet is almost zero. Thanks again
caculation of friction factor Dilip Main CFD Forum 9 February 23, 2016 05:00
Skin Friction and Shockwave evaluate problem mosessitio FLUENT 0 May 21, 2011 03:21
Skin Friction and Shockwave evaluate mosessitio FLUENT 0 May 20, 2011 20:30
Skin friction in fluent is wrong syler3321 FLUENT 2 March 24, 2011 08:05
Compute Skin friction coef by hand Francois FLUENT 1 February 10, 2006 06:21
