Need help with something EASY
Old   December 3, 2005, 17:08
Default Need help with something EASY
Naoman
Hello, I am a student working on my senior design project. I need to model a simple fluids problem: cold engine oil being sucked out of an oil pan through a hose (or pipe) by a vacuum.
The volume (~5 quarts) and viscosity of the oil are set, the drain hole is of set diameter (0.3"), the pipe is 0.5" in diameter and of set length (5'). The pressure drop from the vacuum is going to vary, and I want to determine the flow rate out of the pipe due to the vacuum (in order to find the total time for oil removal). If I cannot get a relationship graph of flow rate vs. pressure drop, it is ok to set the pressure drop to, say 5 psi.
I need this for validation purposes of the hand-calculations, but I have no experience in CFD. I tried using the Fluent/GAMBIT software provided on campus and learning how to use it online, but I got practically nowhere. I desperately need a CFD model of this ASAP, if someone could please help me with this. I would really appreciate it.
Thanks
- Naoman
Old   December 5, 2005, 02:36
Default Re: Need help with something EASY
zxaar
What you want to do is anything but EASY (but since you do not have much idea of CFD i can understant why you said so.)
Old   December 5, 2005, 03:31
Naoman
OK then... How difficult would this be? How long might it take for someone experienced in CFD? I need to know if it is even worth attempting at this point. Thanks.
Old   December 13, 2005, 03:06
sivasamy
Nothing is easy in cfd and you can do something.
it will take some time to learn fluent
try this tutorial
http://instruct1.cit.cornell.edu/courses/fluent/
good luck
siva
easy educational compressible navier stokes implementation anywhere? Boogiwoogie Main CFD Forum 0 December 19, 2010 07:32
Problems with convergence with an easy system franzdrs Main CFD Forum 0 June 15, 2009 19:17
easy to use hex mesher? stu CFX 6 June 9, 2007 11:04
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 17:45
Easy way for a last output at the end of an calculation andimb OpenFOAM 1 April 28, 2006 05:21
