-   FLUENT (
-   -   to run fluent is AMD better or Intel (
ye December 15, 2005 00:19
can any body provide a information
Charles December 15, 2005 02:42
Re: to run fluent is AMD better or Intel
Send me an e-mail and I will send you the result of some benchmarks I did. But the conclusion was that there is little in it, unless running 64-bit Linux, 64-bit Fluent and double precision, in which case there was a significant (about 20%) performance advantage to AMD.
Anne December 17, 2005 05:24
Hi, I compared 3 computers with two small and medium size models in window 2000 OS.
Used Hardware are Intel P-III GEON 1.0GHz 2GB RAM Intel P-IV Prescott 530 (3.0GHz) 512MB RAM AMD Athlon XP Thoroughbred-B 2.08GHz 1.0GB RAM
Used model Smll : 2D mesh : ~200,000 Medium : 3D mesh : ~1,300,000
Calculation time (k-e model + DO model + steady state)
Smll Medium Intel P-III GEON ~16.8 hours ~86 hours Intel P-IV 530 ~3.2 hours ~120hours AMD athlon XP ~6.8 hours ~155 hours
Where calculation time were come from 10,000 iteration.
Above comparison simply illustrtes that Medium case is strongy dependent on memory size. In ddition, CPU speed is major to reuce caculating time, if memory is enough.
I am not sure how much recent 64BIT system with 64Bit OS reduced calculation time. Anyway, as well as CPU clock speed, I believe L1 and L2 cach are another source to determine calculation time.
Rucy December 21, 2005 20:34
I am already using a 64bit machine, and would like to know how to get the 64bit system (Windows + Flueng)?
Best regards
