Home > Forums > FLUENT
error in fluent
Old   December 20, 2005, 06:16
Default error in fluent
vivek
Mine is a 3D geometry wherein I used tetrahedron cells to mesh the entire geometry. The mesh file is read in Fluent and suitable inputs were given. After clicking on "Initialise" it is showing " could'nt allocate fine level coefficient matrix". Kindly suggest me to overcome this error.
Thanks in advance
Old   December 20, 2005, 08:42
Default Re: error in fluent
HS
As far as I know, this error can occur for example when trying to initialize a solution to a large mesh with the coupled implicit solver and your computer does not have enough memory to do that. If that is the case, changing the solver (to either coupled explicit or segregated) or using a less dense mesh, or even changing computer or amount of memory will help you.
Good luck!
/Henrik
Old   December 20, 2005, 11:36
vivek
Thank you very much sir for your advice. It worked. I am grateful to you.
Thread Tools
Trackbacks are On
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 7 May 22, 2014 22:30
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 11 December 8, 2013 10:00
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
