solid surface's emissivity
Old   December 21, 2005, 05:25
Default solid surface's emissivity
jarno brunetti
I have meshed adiacents fluid and solid regions, separates by wall and wall-shadow boundary zones. Where must I specify the solid surface's emissivity? I have seen that there is an "internal emissivity" coefficient" under wall and wall-shadow boundary panel; there is also a "absorption coeffcient" under solid materials panel, but I don't know if these coefficients are these that I'm finding. Thanks
Old   December 22, 2005, 21:51
Default Re: solid surface's emissivity
wheels
I am also puzzled by these two coeffcient ...but they have different unit. At present,I think absorption coefficent can be use as semi-transparent material .and set a series of coefficent for non-gray material. One of these coefficent should be his emissivity at his body temperature. those is my opinion .you are wellcome to discuss about it.
Old   December 23, 2005, 04:54
jarno
Thanks for your response. I have read the discussion that you can find at: http://www.cfd-online.com/Forum/flue....cgi/read/3476, and I think that suggested strategy should be correct. Solid region doesn't take part in radiation because it's its boundary surfaces that absorbs the radiation emitted by C02 and H20 (methane-air combustion case). Radiation heat is transferred, by conduction, across the solid. In this moment I'm trying these strategy and I 'll soon expose the results of simulation. Best regards
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 3, 2013 23:04
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
solid surface's emissivity jarno brunetti FLUENT 0 December 21, 2005 04:51
