Home > Forums > FLUENT
Influence of turb. intensity at the inlet?
Old   December 21, 2005, 19:15
Default Influence of turb. intensity at the inlet?
Ianina
one question about turbulence intensity:
I am modeling the flow past a bluff body (hemisphere) attached to a wall of a channel. Conditions: turbulent, subcritical. I am using k-omega SST turbulent model with appropriate grid resolution near the wall (y+ = 0.5 at max). Also second order discretization schemes are used. The body is placed approx. 6 diameters downstream from the inlet to investigate the effect of different gradients in velocity profile. Turbulence intensity is given according the recommendations of Fluent manual (in this case about 4%)
I would like to ask for the opinion on following: comparing the distributions of Cp with the wind channel experiments i get a different position of min Cp (at 80 degrees) as it was measured (at 75-78 degrees) and consequentially later separation. In this case solution converges to a steady state. I tried to set the turb. intensity to 1 % and got separation earlier but solution does not converge any more to a steady state. Is it physical behavior or the problem of the turbulence model? I noticed some messages on the problems with convergence at a low turbulence level in the forum before.
Any opinion is highly appreciated
Ianina
Thread Tools
Trackbacks are On
Setting dynamic pressure as the inlet BC ruined FLUENT 1 March 26, 2008 06:30
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 15:57
Low Inlet Turb. Intensity - SST model not converge Pete CFX 0 November 12, 2005 02:26
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
length scales at inlet for internal flows Anne-Marie Giroux Main CFD Forum 3 July 5, 1999 21:28
