Time step size
Old   December 22, 2005, 19:05
Default Time step size
Mike
I've modeled vortex shedding using a time step that is 1/30 of the period of shedding(Fluent manual suggests at least 1/20) with good results. For the Re #'s and Str #'s I've been looking at this corresponds to a step of approx. 0.03 s. Yet, I've read several postings where someone is modeling a similar phenomenon, shedding from a cir. cylinder for example, and they're using a delta t aound 0.00001. Why so small?
Old   December 23, 2005, 23:00
Default Re: Time step size
Muhammad Shakaib
The period of shedding and time step required for flow around cylinder in narrow channels is much less. May be these postings are for these cases.
Old   December 25, 2005, 23:39
Mike
Sounds reasonable. I've actually modeled a thin plate in a channel for different blockage ratios and found that the Str# does increase significantly, but I didn't have to decrease my time step size quite so small to capture 1/30th of the period. Thanks
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
natural convection - time step size co2 FLUENT 7 June 3, 2004 21:56
how to increase time step size? co2 FLUENT 6 May 17, 2004 07:25
