-   -   Urgent! Help on UDF (http://www.cfd-online.com/Forums/fluent/39020-urgent-help-udf.html)
Ray Hong December 22, 2005 08:19
Urgent! Help on UDF
Hi there,
I tried to use "compiled" UDF but in vain.
Could you help me to overcome the difficult.
The following is the error message.
Thank you very much in advance.
Ray Hong
Deleted old libudf\ntx86\2ddp\libudf.dll 1 file copied 1 file copied (system "copy C:\FLUENT.INC\fluent6.2.16\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file copied 0 (chdir "libudf")() (chdir "ntx86\2ddp")() udf_inlet.c # Generating udf_names.c because of makefile udf_inlet.obj udf_names.c udf_names.c(6) : error C2061: syntax error : identifier 'keyboard' udf_names.c(6) : error C2059: syntax error : ';' udf_names.c(6) : error C2061: syntax error : identifier 'specified' udf_names.c(6) : error C2059: syntax error : ';'
Done. "d:/cfd/2d-jet/0.5/1"
Opening library "libudf"... Error: open_udf_library: system can not find specified file
Error Object: ()
shashikant December 22, 2005 10:43
Re: Urgent! Help on UDF
are u using windows version of unix version
if windows install visual studio 6 and enable environment variable during instalation of VS6
this will solve ur problem
