What's the meaning of Cm (moment coefficient)?
Old   December 26, 2005, 03:54
Default What's the meaning of Cm (moment coefficient)?
Pathway
I research the wind turbine and use Fluent to simulate problems. I want to know the moment of wind turbine and Fluent can report Cm. Therefore I don't know the meanings of Cm definitely. I had found all the PDF files of Fluent, but I can't find the meanings of Cm (moment coefficient)? I not only want to know the physical meanings of Cm but also its mathematics' equation. Thank you so much!
Old   January 5, 2006, 12:11
Default Re: What's the meaning of Cm (moment coefficient)?
sharuk
it's good i find someone working on the same area, the moment which fluent refers is the torque coeffcient of the rotor,
Old   January 5, 2006, 23:31
Pathway
Thank you for your response. And I want to know where you find this relationship. What the relationship between Cm and torgue? Sincerely.
Old   January 5, 2006, 23:41
sharuk
if u've any idea about ur generator torque and blade inertia, then u can find the rpm of the ur rotor at desired TSR, so giving same inputs to fluent, the aerodynamic moment of ur rotor/blade u get is equal to ur torque.
Old   January 5, 2006, 23:50
Pathway
Thank you so much. And I will try the method you said.
Old   January 6, 2006, 02:45
Bunmi
Cm is the convergence history of your moment
2D Airfoil Centre of Pressure, Pitch Moment and Pitch Moment Coefficient aerospain ANSYS 2 May 4, 2020 20:47
Moment Coefficient of 2D Airfoil yellowCamel STAR-CCM+ 4 August 27, 2011 05:41
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:56
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 06:51
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
