-   -   user-defined functions (http://www.cfd-online.com/Forums/fluent/39096-user-defined-functions.html)
Yucel Ozmen January 2, 2006 10:01
Dear Fluent Users,
I am PhD student and I am using Fluent in the numerical part of my PhD.I am trying to solve flow field around roof models with different slopes immersed ABL in 2D. I am trying to give inlet_velocity,turb. kinetic energy and dissipation rate profiles with udf.But I have a problem. I want to give my experimental profiles with udf as inlet boundary conditions.I don't want to use standard udf approaches given with formulas (power law, friction velocity,wall shear ect.)Because, this standard profiles don't fit with exp. data. is it possible to read these exp. data into udf code? and is it possible to appoint these data to F_PROFILE macro without using loop? Can I use this kind of udf code in the Fluent? Can you help me for this problem, I would be very happy. Best regards
Yucel Ozmen Dept. of Mech. Eng. Karadeniz Technical University 61080 Trabzon - TURKEY e-mail:yozmen@ktu.edu.tr
Yucel Ozmen January 2, 2006 17:46
Re: user-defined functions *NM*
John January 4, 2006 11:18
Hi Yucel,
Please look at Solution 1338 on the Fluent User Services Center. It is an example of using experimental data for viscosity, but should be easily adapted for your purpose.
Regards,
John
