January 3, 2006, 03:18 |
error while iteration
Dear all,
I have met with some problems in using fluent to simulate the flow of a liquid with an air bubble in a square channel. I am using VOF model to simulate this flow. The problem I met with is that whenever I input a value for the surface tension between the liquid and the gas, I will receive an error message while iterating. Error message: "Too many sub time step. The velocity field is probably diverging……..Reduce time step" I hope you all can give me some advice regarding this problem Best Regards |
how to increase "Newton Pressure Iteration Limit" | kus | CFX | 9 | April 21, 2013 01:54 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 22:30 |
Creating, loop or iteration using expression edito | Jan | CFX | 3 | July 28, 2003 11:01 |
Heat exchanger problem | chiseung | FLUENT | 16 | October 20, 2001 04:36 |
