writing vel. profile with journal file
Hi!
I'm trying to write the x-,y-,z-vel. and the vel.-magnitude on several surfaces (y_0630, y_0730, ...) for several cases (05, 06, ...) into profile files using a journal file. But its not working properly... whats wrong?? Ralf rc 05.cas yes rd 05.dat //file/write-profile 05_y0630.txt y_0630 velocity-magnitude x-velocity y-velocity z-velocity q //file/write-profile 05_y0730.txt y_0730 velocity-magnitude x-velocity y-velocity z-velocity q rc 06.cas yes rd 06.dat //file/write-profile 06_y0630.txt y_0630 velocity-magnitude x-velocity y-velocity z-velocity q //file/write-profile 06_y0730.txt y_0730 velocity-magnitude x-velocity y-velocity z-velocity q |
the error message
> rd ch00_1,4kg-s_mod05.dat
Reading "ch00_1,4kg-s_mod05.dat"... Parallel variables... Done. > adapt/ file/ report/ define/ grid/ solve/ display/ parallel/ surface/ exit plot/ view/ > //file/write-profile ch00_1,4kg-s_mod05_y0630.txt y_0630 surface(2) [()] velocity-magnitude surface(3) [()] x-velocity surface(4) [()] y-velocity surface(5) [()] z-velocity q surface(7) [()] Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f |
that is working!
I've got it! I dont know the difference, but its working! There are not enough return or something...
rc ch00_1,4kg-s_mod05.cas yes rd ch00_1,4kg-s_mod05.dat //file/write-profile ch00_1,4kg-s_mod05_y0630.txt y_0630 velocity-magnitude x-velocity y-velocity z-velocity / //file/write-profile ch00_1,4kg-s_mod05_y0730.txt y_0730 velocity-magnitude x-velocity y-velocity z-velocity / |
