Unstructured grid problem - Laminar flow pipe |
January 12, 2006, 05:54 |
In order to perform complex pipe geometry with laminar flow simulations, i've tried to mesh a simple straight duct with a t-grid scheme using the size function in gambit to preserve the boundary layer detection. I set an udf to have a laminar fully developed flow profile at the inlet. I set a size function in gambit to obtain a value of about R/38 for the first cell height as suggested by the fluent manual. I set outflow for the outlet bc. The results i obteined are unespected... e.g. the max velocity plotted on an axial line decreased of about 20% respect to the max inlet value! I've checked the mass balance and it seems to be all right. With structured mesh i obtained good results. Have you got any ideas for non structured grids?!?! I thought it could be a not correct prediction of the boundary layer flow or even some solver parameter i missed...
thanks in advance. |
code for SIMPLE algorithm - 2D Lid driven cavity flow problem - Collocated grid | h_amooie | OpenFOAM Programming & Development | 1 | January 22, 2022 11:33 |
Problem with laminar 2d channel flow | Quarkz | Main CFD Forum | 6 | October 7, 2015 12:24 |
pipe flow problem | RodriguezFatz | FLUENT | 2 | August 9, 2011 07:59 |
air flow in pipe with heat problem | keng | Main CFD Forum | 1 | March 5, 2010 10:40 |
Laminar Pipe Flow Simulation/Help Please | Colin | FLUENT | 3 | May 6, 2003 23:07 |
